Oil pressure gauge needle...
Old Sep 22, 2007 | 05:38 PM
wrd1972's Avatar
When you guys turn the key to the on position (without starting), where does your oil pressure needle point. Does it point to 0 or the red area indicating low pressure.
Mine points slightly above the red area indicating low pressure when the key is in the on position (engine not running).
I have had the needle off and I am wondering if it is set correctly.
Old Sep 22, 2007 | 05:50 PM
SS RRR's Avatar
Stock gauges are nothing more than a point of reference. You want accuracy then put in a mechanical gauge.
Old Sep 22, 2007 | 05:53 PM
Pyrodawg's Avatar
the oil pressure gauge shouldnt move until you try cranking the car
Old Sep 22, 2007 | 06:01 PM
Mine points right at zero when the key is turned to ON.
Old Sep 22, 2007 | 06:22 PM
wrd1972's Avatar
I understand this statement, but this does not answer the question...
This answers the question. Thanks Shoebox.
Old Sep 22, 2007 | 08:52 PM
SS RRR's Avatar
I'm terribly sorry, for the nature of your question seemed to pose it was some sort of problem the gauge was not pointing to zero with KOEO.
My humblest apologies.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
KYWes
Apr 15, 2015 05:48 AM
Z28countrymama
Jan 22, 2015 02:50 AM
