Oil pressure gauge needle...
When you guys turn the key to the on position (without starting), where does your oil pressure needle point. Does it point to 0 or the red area indicating low pressure.
Mine points slightly above the red area indicating low pressure when the key is in the on position (engine not running).
I have had the needle off and I am wondering if it is set correctly.
I understand this statement, but this does not answer the question...
This answers the question. Thanks Shoebox.
I'm terribly sorry, for the nature of your question seemed to pose it was some sort of problem the gauge was not pointing to zero with KOEO.
My humblest apologies.
