Oil Pressure Fluctuations
Old Jun 25, 2003 | 09:51 PM
94GreenZ28's Avatar
How bad is that at idle my oil pressure will fluctuate once in a while from 15 to 20 psi then go back down to 15? Is there anything I can do. Engine doesn't sound any different. No noises.
Old Jun 25, 2003 | 10:02 PM
boosted3.8's Avatar
Are you going from the gauge in the car? If so I would check it with a test gauge just to be sure. Since the pressure isn't really low I wouldn't suspect the bearings or anythin like that. Just maybe a funky check valve or somethin of the like. It's not a good thing but since pressure only drops to 15 nothing really bad should happen.
Old Jun 25, 2003 | 10:10 PM
94GreenZ28's Avatar
should i try running some kind of engine cleaner through or try putting some marvel oil treatment in or something? Or maybe should I clean the sending unit?
Old Jun 25, 2003 | 10:14 PM
Might just be the sensor.
I changed my sensor a while back and got almost a 10 psi increase. Was the old sensor giving me the correct pressure or is the new one? I don't know, but I am more content with the higher reading.
Old Jun 25, 2003 | 10:19 PM
94GreenZ28's Avatar
Ya I'm alittle worried but atleast it never drops below 15 psi.
Old Jun 25, 2003 | 10:29 PM
IrocManiac's Avatar
Check the sensor, but 15 psi isn't bad...now 10 or 8 or 5 psi you've got some serious issues.
Old Jun 25, 2003 | 10:32 PM
Koby's Avatar
lol, when my car idles the oil pressure is never above 10 psi. If I get on it then it goes up to around 40. Still need to fix that darn leak
Old Jun 25, 2003 | 10:44 PM
IrocManiac's Avatar
How bad a leak? Lots of cars have MINOR oil leaks and the pressure will be ok...you could have a bearing(s) going down on you.
Old Jun 25, 2003 | 11:48 PM
94GreenZ28's Avatar
I just checked it again when the car is warm. I reved it up and it will drop to about 30 psi then fluctuate about +- 5 psi (which is about 1/8" on the gauge) then after about 10 seconds drop to about 22 psi (right above the first mark) and then stay steady. Does that sound about right guys?
Old Jun 26, 2003 | 12:04 AM
IrocManiac's Avatar
Yeah thats about right.
Old Jul 19, 2003 | 06:28 PM
Koby's Avatar
My leak is pretty good. When I change my oil, if I don't add any to it, I usually lose about a quart or more of oil. Outside the car you can smell the burn oil pretty bad.
Old Jul 24, 2003 | 02:29 PM
94GreenZ28's Avatar
fixed my problem with a moroso windage tray and baffle
Old Aug 19, 2003 | 03:08 PM
EaC95Z28's Avatar
94 green z28=
man my guage did the exact same thing. is that okay guys? cause im afraid i might have to change out my oil pressure sensor and i would rather not! i dont think it is anything wrong because it always has constant oil pressure when im driving. i just noticed it last night. i would be at a stop light and idling when the car is warmed up and it would do the same thing 94greenz28's car did which is about 30psi and fluctuate 5 psi or so and then stay steady at around 25 or so psi. i think its okay because when its idiling after a whiel it stays steady i just hope my sensor is fine. thanks! also 94 what is a moroso windage tray and balffle and what do you do with it and also hwo much does it cost where can i get it from?
Old Aug 20, 2003 | 03:54 PM
vbooe's Avatar
oil pressure fluctuations
I have a 95z automatic with LT1. I bought the car about 2 years ago and the oil pressure gauge has always fluctuated between 20 and 40. Recently, I have noticed sitting at the stop light the pressure has been dropping under 20 (engine warm). I am now curious about what the actual pressure should be at idle. Pressure gauge goes back up to 40 when under power but drops considerably (not under 10) when not under power. Can anyone help me figure out if I need to be worried about this or not?
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
