Oil pressure drop.
Old Jan 17, 2006 | 02:34 PM
96ta(nick)'s Avatar
Oil pressure drop.
My oil pressure builds up untill about 6k rpms and then drops off from around 60psi to 45psi then fluctuates. I tried 10w40 and 10w30 both of which do the same. This is in my fresh 357 with a stock pump and a TPIS oil pan with trap doors,windage tray, and crank scraper. Any ideas as to what could be causing this?
Old Jan 17, 2006 | 04:21 PM
Digital Designs's Avatar
Re: Oil pressure drop.
faulty sensor, or the pressure bypass spring is worn
Old Jan 17, 2006 | 05:37 PM
atljar's Avatar
Very likely a restriction in the filter setup. i fought the same thing with the new motor. Try a high flow filter like the Wix Racing 1 Qt. (1060R)
Old Jan 17, 2006 | 06:20 PM
96ta(nick)'s Avatar
I have a brand new mobil 1 filter with 5 miles on it.
Old Jan 17, 2006 | 07:14 PM
jsetzer's Avatar
I am building the exact same motor as Nick, so I am sharing some of the concerns.
He (we) have a melling standard volume pump with the stock spring. I have not seen the car drop to 45psi as Nick states, but it def does not build past 60 at high rpms. I think that the stiffer spring would def help us out.
Is it worth pulling the pan again to swap them? Will we do any damage with the way things are now?
Old Jan 18, 2006 | 12:30 AM
atljar's Avatar
Ya i tried all sorts of brand new filters with mine too and some of them wont keep up with it.
Whats a 12 dollar filter and 1 qt of oil cost to change vs.....time pulling the pan and changing out the spring. KISS
Old Jan 18, 2006 | 01:24 AM
turbo_Z's Avatar
Ive noticed different filters and different oils doing the same thing on my car. It seemed like the THINNER oils held better pressure. Currently I use M1 filter with Mobil 5000 5w30.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
