oil pressure
Old Mar 26, 2012 | 06:14 PM
1eez28's Avatar
oil pressure
i have a rebuild engine and when i start it the oil pressure gauge doesnt move. Any thoughts?
Old Mar 26, 2012 | 06:17 PM
RamAir95TA's Avatar
Re: oil pressure
Did you prime the motor before you ran it?
Is the gauge on 0 or pegged to the max?
Old Mar 26, 2012 | 06:22 PM
1eez28's Avatar
Re: oil pressure
no and its at 0 doesnt move at all from when its on or off
Old Mar 26, 2012 | 06:23 PM
RamAir95TA's Avatar
Re: oil pressure
If the motor wasn't primed, remove the injector fuses and turn the motor over (assuming you have oil in the pan) until you get oil pressure. It also might help to put a mechanical gauge on the car to determine whether or not the oil pressure sending unit is functioning.
Old Mar 26, 2012 | 06:25 PM
1eez28's Avatar
Re: oil pressure
thanks man. ill try it
Old Mar 26, 2012 | 06:37 PM
1eez28's Avatar
Re: oil pressure
well that didnt work
Old Mar 26, 2012 | 07:07 PM
RamAir95TA's Avatar
Re: oil pressure
If the motor was never primed that's just poor workmanship on the shop who did the work. At this point I'd consider taking off the intake manifold and manually priming the oil pump.
Old Mar 26, 2012 | 07:09 PM
lt1-xjs's Avatar
Re: oil pressure
Is the gauge hooked up to the sending unit ?
Old Mar 26, 2012 | 07:10 PM
RamAir95TA's Avatar
Re: oil pressure
If the gauge wasn't hooked up the needle would be pegged, that's why I asked.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
