Oil Pressure
Old Aug 13, 2006 | 01:17 AM
  #31
hvyss's Avatar
Re: Oil Pressure
When I rebuilt my motor agian{dropped the pickup spinning a rod bearing} I got rid of the Meling HV pump with the stock pan{sucking the pan dry at Wot causing a 10 psi drop in pressure} and went back to a LT1 standard volume pump with a high pressure spring{White}. Cold the car idles at 70psi. Warm it idles at 22-25 psi with an 850-900 rpm idle. Above 2500 rpms it runs 62-65 psi. Much happier with the results.
HVY SS
Old Aug 13, 2006 | 08:14 AM
  #32
Re: Oil Pressure
Originally Posted by bow94z
So is there a part # and price on this oil pressure sensor?
There is, on my Tech Page.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
