oil pressure
Old Jul 24, 2005 | 01:30 AM
95z28txn's Avatar
oil pressure
what kind of oil pressure should i expect with 100 outside temp and all my upgrades plus 1.6 roller rockers and no fan @ 210 degrees in the motor. p.s. i just had my bottom end rebuilt with no oil gatherer in the bottom end.
Old Jul 24, 2005 | 02:45 AM
GreenDemon's Avatar
Re: oil pressure
Huh? Do you mean no pickup?
Close to 20 psi at idle seems to be the norm for a street LT1. Any less than that and I would investigate.
Old Jul 24, 2005 | 09:18 AM
95z28txn's Avatar
Re: oil pressure
the metal plate that is atatched to the main bolts is no longer in my pan. 20 sounds good because i was just above that.
Old Jul 24, 2005 | 12:01 PM
1racerdude's Avatar
Re: oil pressure
With no baffle ya are just begging for pressure problem's when accelerating. Could lead to a blown motor.
Old Jul 24, 2005 | 12:44 PM
matLT1's Avatar
Re: oil pressure
I don't think he is talking about the pickup, he is talking about the windage tray that keeps the crank from sweeping up oil at high rpm.
Old Jul 24, 2005 | 01:23 PM
95z28txn's Avatar
Re: oil pressure
which ever peice is bolted to the main
Old Jul 24, 2005 | 02:55 PM
ZU_LTR's Avatar
Re: oil pressure
20psi is about average , and is what I would say everyone of our LT1's run at. and I wouldn't be messin' around by removing baffles or whatever ,these cars run with low pressure as is and you don't want to lose anymore oil pressure.
Old Jul 24, 2005 | 03:43 PM
95z28txn's Avatar
Re: oil pressure
thanks for the help guys the info sounds good
Old Jul 24, 2005 | 03:50 PM
FastZinTennessee's Avatar
Re: oil pressure
That's your windage tray that attached to the mains, and yes it's a really good idea to have one.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
