oil pick up
Old Sep 20, 2011 | 08:11 PM
twistedbowtie's Avatar
oil pick up
hey guys my 1995 z28 have low oil pressure at warm idel im thinking it could be the oil pick up tube. i recently replaced the oil pan gasket and maybe i hit the tube and pushed it up to far. could i possibly put a few extra quarts in it to check before pulling the pan off?
thanks, Dustyn
Old Sep 20, 2011 | 09:10 PM
raroz28's Avatar
Re: oil pick up
thanks, Dustyn
you gotta hit that tube hard to knock it loose. Drain the oil and hit the pan with a rubber mallet. if you hear a bounce then it's out. If not, then it isn't the problem.
Old Sep 21, 2011 | 11:02 PM
Re: oil pick up
You don't want to add oil above the "full" line.... you'll whip it into a froth with the crank, and air will enter the oil system.
The common symptom of the pickup falling off would be a "0" pressure on hard stops. Having the pickup moved higher than its supposed to be would affect oil pressure more at high RPM than at idle.
Nickster 7
May 1, 2015 09:04 PM
4586
Apr 29, 2015 01:43 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
