Ok, I've already figured out that on my M6 I have to drop the K member as well as jack up the engine to get the oil pan off. But what are the specs of the oil pan. Also does the oil pump have any torque specs? If so what are they as well? Thanks!
Oil Pan Corner Bolt
15 ft/lbs
Oil Pan Side Rail Bolt
8.3 ft/lbs
Oil Pan Baffle Nut
25 ft/lbs
Oil Pan Drain Plug
16 ft/lbs
From the complete torque specs list. (Bookmark it)
http://www.bfranker.badz28.com/fbody/torquespecs.htm
15 ft/lbs
8.3 ft/lbs
Oil Pan Baffle Nut
25 ft/lbs
Oil Pan Drain Plug
16 ft/lbs
