Oil pan torque specs
Old May 3, 2004 | 01:39 PM
Red96Lt1's Avatar
Ok, I've already figured out that on my M6 I have to drop the K member as well as jack up the engine to get the oil pan off. But what are the specs of the oil pan. Also does the oil pump have any torque specs? If so what are they as well? Thanks!
Old May 3, 2004 | 03:02 PM
Spinner's Avatar
Oil Pan Corner Bolt
15 ft/lbs
Oil Pan Side Rail Bolt
8.3 ft/lbs
Oil Pan Baffle Nut
25 ft/lbs
Oil Pan Drain Plug
16 ft/lbs
From the complete torque specs list. (Bookmark it)
http://www.bfranker.badz28.com/fbody/torquespecs.htm
Old May 3, 2004 | 09:05 PM
Red96Lt1's Avatar
What's the oil pan baffle nut? Is it in the oil pan?
Old May 3, 2004 | 09:26 PM
Spinner's Avatar
I think that's the windage tray inside the pan
HectorM52
Jul 30, 2017 11:46 AM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
