Oil Pan Removal
Re: Oil Pan Removal
Originally Posted by CColtManM
Can someone confirm this?
I hope this is true as I would like to check on my oil pick up and also see what crap I have in the bottom of the oil pan.
Re: Oil Pan Removal
You have to lift the engine 3" EVEN WITH AN AUTO. The reason is because you have to clear the crank. There's not enough room between the block and k-member to get it past the crank with the engine mounts still bolted.
Frank
Frank
