Oil Pan/pump/pickup
Old Oct 28, 2005 | 10:17 AM
blahster's Avatar
Oil Pan/pump/pickup
Cheapest yet good oil pan/pump/pickup setup for my LT1 4bolt LE3 engine?
i will need these for my new engine....recommendations???
TIA!!!!
Old Oct 28, 2005 | 02:41 PM
sssalah's Avatar
Re: Oil Pan/pump/pickup
TIA!!!!
The stock oil system should fit the criteria. I believe some very powerful cars are running the stock oil pan with a high pressure spring in the stock pump.
As for aftermarket, I think the only option is the canton which I'm running only because I didn't wanted to modify my stock pan to clear the larger stroke.
Old Oct 28, 2005 | 04:25 PM
FastZinTennessee's Avatar
I've got the Canton pan as well. Don't really remember where I bought it from- just did a goodle search on "Canton Racing Oil Pans" and found the cheapest place. You can get the pan, pickup and pump all from the same place. You'll probably spend somewhere between 4-$500 if you want to go that route.
I believe Summit sells some Milodon oil pans that might work, and they carry the pickup also.
Old Oct 28, 2005 | 04:41 PM
Victory Racing's Avatar
There is also a pan made my Moroso.
Old Nov 18, 2005 | 10:09 PM
KGRESOCK's Avatar
Would you happen to have the part number?
Old Nov 19, 2005 | 07:36 AM
Eric@Victory Racing's Avatar
Moroso Part number #20182.
Says it is for a 86-92 SBC, but we have used it on many LT1's without an issue. The only thing that goes away is the oil level sensor that installs into the side of the factory pan.
Old Nov 19, 2005 | 08:12 AM
rskrause's Avatar
Moderator
There's nothing wrong with a stock pan, pump, and pickup. Use a high pressure spring with the pump and inspect it. Here's some links to oil pump info: http://www.aa1car.com/library/2004/eb10445.htm and chevyhiperformance.com/techarticles/148_0506_how/
I would caution strongly against installing a HV pump with the stock pan. If you are using an aftermarket pan, a HV pump is ok though not needed unless the motor has loose bearing clearances.
Rich
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
