Oil Pan Gaskets
not knowing what tranny you have, remove y-pipe, loosen and lower trans pan, remove pan ensuring all crank balance throws are up in the block(to provide clearence for the front lip of the pan. 1-2 hours with a lift, no lift-have fun.
Originally posted by c0rey
what weight of oil should i use 10-30? i got 82k
GM recommends 5w-30, and especially since you are in NB and your car is likely to be exposed to temps <0*, that's what I would go with.
