Oil Pan Gasket Extras
Old Aug 23, 2009 | 11:49 AM
Future_Z_Owner's Avatar
So i went to get a new oil pan gasket today. I got a Fel Pro Perma Seal and it came with some extras. Pictured below are some o rings and some paper gaskets that came with it. Just wondering what they are for? Also i hear i should not use RTV on this gasket. Is this true? Thanks
Old Aug 23, 2009 | 12:12 PM
SmokeyBlaZe's Avatar
I'm wondering the same thing my gasket set is OS34500R , I also heard to install it dry or use "the right stuff"
Old Aug 23, 2009 | 12:41 PM
Stl94LT1's Avatar
The extra gaskets and large o-rings are for the oil filter adapter/oil cooler.
Old Aug 23, 2009 | 04:23 PM
Nobody knows for sure?
Old Aug 23, 2009 | 04:42 PM
Stl94LT1's Avatar
Check post #3!!
I installed my Felpro oil pan gasket dry 6 years ago, and no leaks since.
Old Aug 23, 2009 | 05:20 PM
RamAir95TA's Avatar
Another vote for installing it dry. As long as everything is clean and burr-free, there's no reason you should use RTV.
Old Aug 23, 2009 | 06:00 PM
bw_hunter's Avatar
Use RTV at the front and back...where the gasket goes over the timing cover and rear main..... and dry everywhere else.
I've done it this way many times and never has a leak.
Old Aug 23, 2009 | 06:12 PM
Thanks guys!
BW Hunter, ive heard about putting it there on the corners of the rear main and the timing cover because they apparently leak there often. Thanks for the tip.
So i took all the RTV i had on the pan off... Dont ask long story. Anyways i lost a bit of the paint on the seal area aswel. Is this going to cause any issues? I was told no and that i could spray some paint on any paintless surface of the pan once its mounted to the motor to prevent rust. But the unpainted area around the gasket will be fine. Do you guys agree?
Old Aug 24, 2009 | 10:51 PM
SlowMoComotion's Avatar
I was told to do so on my LT1 by a few experienced techs as well.
To answer original question #3 has it right.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
