Oil pan gasket
Old Feb 5, 2006 | 03:43 PM
LT193's Avatar
Oil pan gasket
I just replaced the oil pan gasket and i have realized its the front and rear main seal aswell. This is a really dumb desighn as i almost had to pull out the motor to do this (it was a pain not pulling it and doing it) just wondering if anyone else has done this with the pan in the car, and if so how do u do a camshaft withought having to do this all the time?
Old Feb 5, 2006 | 05:31 PM
Javier97Z28's Avatar
Moderator
Re: Oil pan gasket
When you do a cam install you drop the front of the pan some and sometimes you'll be able to pull the timing cover out without ripping, and sometimes you won't.
Mine ripped during my first cam install. I'm borrowing a cherry picker during my current heads/cam install to support the motor, dropping my kmember to replace the pan gasket.
Old Feb 5, 2006 | 07:42 PM
stroked383z28's Avatar
Re: Oil pan gasket
Just take out all the pan bolts and slide the new gasket over the oil pan from underneath.
Old Feb 5, 2006 | 07:47 PM
1racerdude's Avatar
Re: Oil pan gasket
Use the OLD style gasket that has cork on the side rails. This way the pan will pull down and not leak instead of the torque spacers for the silicone gasket to not squish the gasket out the side
Old Feb 5, 2006 | 09:10 PM
Moderator
Re: Oil pan gasket
Is this a felpro item? How do you differentiate/order it?
Torque specs, different? RTV in any locations when using it?
Old Feb 5, 2006 | 09:16 PM
1racerdude's Avatar
Re: Oil pan gasket
Order it for say a '79 model or just ask for a cork gasket for a SBC, RTV in the four corners and white lube on the end rubbers so it will slip when the pan grabs it instead of pulling it and making it thin on the very bottom of the "U".
Old Feb 5, 2006 | 09:35 PM
Josh'95Z28conv's Avatar
Re: Oil pan gasket
Dude, just slide the silicone gasket over the outside of the pan. Its a piece of cake. Ive done it several times to different LT1's. There is only a couple inches between the block and pan, but thats enough to get a rag in there and wipe the surface clean. At most, just take the motor mount bolts out, and lift the engine a couple inches. Thats way more than enough room to replace a pan gasket.
Old Feb 6, 2006 | 12:03 AM
Re: Oil pan gasket
Right on. I use felpro #1886. No sealant of any kind and no leaks!!!
Old Feb 6, 2006 | 12:25 AM
Re: Oil pan gasket
I still put a little silicone in the four corners where the block meets the timing cover, and rear seal plate in the rear. Its probably not needed, but its peace of mind
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
