oil pan gasket
Old Jul 9, 2005 | 02:23 AM
ruqwknf's Avatar
oil pan gasket
if anyone can help withthis what is the easiest way to change the oilpan gasket.. do i have to drop the cross member?
Old Jul 9, 2005 | 02:32 AM
ruqwknf's Avatar
Re: oil pan gasket
Old Jul 9, 2005 | 07:19 AM
PoorMan's Avatar
Re: oil pan gasket
I didn't. The front cover will need to be removed first. The pan drops an inch or so. It's enough to get it on. I believe I had to remove the oil pan sensor and oil filter. Been awhile; cann't remember. I have LT's btw so you may need to remove y-pipe if you have one.
http://community.webshots.com/photo/...68330640ncxlEM
JD
Old Jul 9, 2005 | 08:11 AM
Dave89IROC's Avatar
Re: oil pan gasket
JD
umm.........why remove the front cover???? the oil pan gasket fits into a groove in it, you should leave the cover in place
Old Jul 9, 2005 | 08:14 AM
Re: oil pan gasket
JD
I don't understand why you would remove the front cover first, as the oil pan seals to the cover after it is installed.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
