oil pan gasket
Old Mar 7, 2004 | 05:32 PM
ajschult's Avatar
oil pan gasket
Well my car is leaking oil like mad. Anyone know how hard it is to change a oil pan gasket or a timing chain cover gasket?
Old Mar 7, 2004 | 09:45 PM
OBE1 95Z28's Avatar
I helped my friend change both a couple of months ago. You'll need to drop the cross member to get the oil pan off; we supported the engine with a Happy Hooker (bracket that mounts to the intake) and an engine hoist. Once the cross member is out of the way the oil pan gasket is easy to change. Make sure you pull the oil level sensor out of the side of the pan before you try to drop the pan. The GM gasket is not a bad piece but I like the Felpro gasket better. The timing chain cover gasket takes a lot more work as you have to pull the waterpump, opti and crank hub off. The seal for the waterpump gear should be replaced and it's a pain to get in without rolling the inner seal.
Old Mar 7, 2004 | 11:58 PM
Lt1t56's Avatar
Timing chain cover seal leak not common, but water pump shaft seal, opti seal or crank seal common leak. Oil pans do leak at times and it not too bad to replace.
Old Mar 8, 2004 | 11:43 AM
jtk's Avatar
jtk
I would make sure its alctualy leaking from the oil pan, those gaskets are one peice silicone gaskets, the only way they are going to leak is if they were broken after a cam install or the bolts are loose
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
