Oil pan drop
Old Nov 25, 2004 | 10:08 AM
wc00ac's Avatar
Oil pan drop
Can I drop the oil pan down with the engine in the car? I have a 94z28.
Old Nov 25, 2004 | 10:50 AM
RCF925's Avatar
Re: Oil pan drop
Yes, Support the frame on jack stands and loosen the 6 K-Member bolts a few turns and it makes it easier to get off. You also may have to raise the motor as far as you can after removing motor mount thru bolts.
Old Nov 25, 2004 | 11:15 AM
wc00ac's Avatar
Re: Oil pan drop
So if I put my car on ramps and loosen the k-member and take the motor mounts off and jack up the motor it can be done.
Old Nov 25, 2004 | 12:40 PM
RCF925's Avatar
Re: Oil pan drop
You have to have the wheels hanging or the K-Member won't drop down.
Old Nov 25, 2004 | 02:25 PM
wc00ac's Avatar
Re: Oil pan drop
Where is a good place for the jack stands? I like to ask cause I dont like using them.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
