Oil pan drop
Re: Oil pan drop
Originally Posted by wc00ac
Can I drop the oil pan down with the engine in the car? I have a 94z28.
Yes, Support the frame on jack stands and loosen the 6 K-Member bolts a few turns and it makes it easier to get off. You also may have to raise the motor as far as you can after removing motor mount thru bolts.
