oil pan
Old Oct 18, 2005 | 05:22 PM
  #16
pearlpurple's Avatar
Re: oil pan
Originally Posted by 93black-ta
why not buy a new standard volume pump. it will be alot cheaper, especially seeing as how you have to drop the pan either way.
This is got my vote, good oil pressure, no problems and everyhting fits nice.
Stock pump gives plenty of pressure and flow anyways.
Old Oct 19, 2005 | 08:39 AM
  #17
EVERESTZ28's Avatar
Re: oil pan
I don't know if this is good or not, but i have seen people how use a high volume-standard presure in stock pan but put in an extra qt of oil.
Old Oct 19, 2005 | 07:41 PM
  #18
mzgp5x's Avatar
Re: oil pan
Went with the Canton LT1 pan. Cross over pipe OK, but I had trouble with the drivers side cat (1997). Ended up with a random Y pipe dual bullit cat, which, really helped out with Bk-pressure. Running a Melling high vol std pressure pump. The Canton does not have much clearance with the stock engine frame cradel @ front, but, I think it is worth it.
HectorM52
Jul 30, 2017 11:46 AM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
