oil pan
Old Oct 17, 2005 | 05:04 PM
camaroKid223's Avatar
oil pan
I installed an melling HV oil pump when I was putting the new motor together and am now hearing that it could cause oil pressure probs and that I should get a bigger oil pan. I can get a good price on a new 7 qoart Moroso oil pan. Will this fit and can I use the melling pump I already have in?
Old Oct 17, 2005 | 06:06 PM
bdc95ta's Avatar
Re: oil pan
yup might need a new pick up though to go w/ the pan.
Old Oct 17, 2005 | 06:44 PM
Re: oil pan
so the pan will fit, great! What pickup should I go with?
Old Oct 17, 2005 | 07:06 PM
bdc95ta's Avatar
Re: oil pan
whatever moroso recomends
Old Oct 17, 2005 | 09:02 PM
SStrokerAce's Avatar
Re: oil pan
Anytime you run a HV pump you need a new pickup. Either way you don't need a HV pump.
Bret
Old Oct 17, 2005 | 09:20 PM
Re: oil pan
well I already have a new pick up for the oil pump, thats not the prob. The prob is with my new motor and new pump I have heard of people losing oil pressure on the stock pan, and although it hasnt happened yet I only have 315 miles on the motor so I dont really want to find out the hard way if I do lose the pressure. I guess I could just replace the pump but why not go with a deep pan and HV pump?
Old Oct 17, 2005 | 09:25 PM
Re: oil pan
You need to make sure you have a windage tray in the pan.
Bret
Old Oct 17, 2005 | 09:33 PM
Re: oil pan
the stock pan has the stock windage tray and the moroso has a windage tray. Should I try and run on the stock pan with the HV pump?
Old Oct 17, 2005 | 09:43 PM
Re: oil pan
If you haven't hurt it yet you might be ok.... Usually it's the combination of a stroker crank, no windage tray, and a HV pump that cause the issues.
Bret
Old Oct 17, 2005 | 09:59 PM
Re: oil pan
well its not a stroker motor and I still have the windage tray. Also right now the oil pressure is fine but my friend built a motor around the same time as me and now has about 500 miles on his and is starting to get pressure probs and we assumed it was the HV pump. You guys think I should stick with the stock pan or no?
Old Oct 18, 2005 | 12:55 AM
1racerdude's Avatar
Re: oil pan
NO get some kind of pan other than stock if ya can.
Old Oct 18, 2005 | 09:23 AM
EVERESTZ28's Avatar
Re: oil pan
may be you want to know that it's possible that your custom y pipe will not fit with a bigger pan, mine does not fit with a 6qt milodon pan.
Old Oct 18, 2005 | 10:41 AM
Re: oil pan
crap I didnt even think about the y-pipe...
Old Oct 18, 2005 | 01:52 PM
EVERESTZ28's Avatar
Re: oil pan
me neither now i'm oppen headers jaja , but i will look into a new one because i don't want a ticket...
Old Oct 18, 2005 | 05:17 PM
93black-ta's Avatar
Re: oil pan
why not buy a new standard volume pump. it will be alot cheaper, especially seeing as how you have to drop the pan either way.
