Oil leaking from valve covers?
Old Sep 1, 2003 | 03:07 AM
Laymaster's Avatar
A while ago I did headers and the Taylor OVC wires. I've noticed that my # 7 and 8 plugs and wires tend to have oil on them, as does the filter and some on the transmission. This is not leaking from the intake manifold as that has been replaced. Did you guys use any type of gasket or even the permatex liquid hi-temp gasket on the valve cover mounts? I didn't, didn't think I was supposed to. The mounts are on the valve covers as much as I can get them on, I tightened them pretty damn well, and I didn't want to snap anything loose but still, it should be plenty tight. Thanks in advance!
Old Sep 1, 2003 | 04:15 AM
Compstall's Avatar
I would definitely go off of the torque specified in a manual, or at least be close to it if you don't use a torque wrench on them. By design, centerbolt valve covers can leak if they're torqued down too much.
Old Sep 1, 2003 | 05:23 AM
anaik's Avatar
Torque is 8.3 lbs-ft or 100 lbs-in.
Old Sep 1, 2003 | 11:27 AM
Laymaster's Avatar
It's definitely as tight or tighter than that. Anyone else running these wires with mobil 1 synthetic?
Old Sep 1, 2003 | 11:45 AM
Hyperspeed97z28's Avatar
is your last plug on the pass side all covered in oil ???
mine is too.... I'm gonna do my valve covers this week.. shouldnt be to bad as i have no AIR and I have headers.. What gaskets are you using? Fel pros? I was think the blue perf with cork would do nice...
Old Sep 1, 2003 | 11:50 AM
Laymaster's Avatar
Yes my plugs are covered in oil! The valve cover gaskets should only have 35-40k on them, or about 2 years of mileage. I don't know what's up with that. As for valve cover gasket? It was replaced with GM OEM. Exhaust gaskets I decided to go with the LT1 Aluminum GM OEM Gaskets as that's what came back as most recommended off the board here.
Old Sep 1, 2003 | 11:56 AM
gb95zconv's Avatar
A couple of things.....I tighten mine all the way down and never have any leaks. Take the cover off and make sure the seal is in correctly and not pinched up. Also make sure its the valve cover leaking and not the intake manifold.
Old Sep 1, 2003 | 11:57 AM
Laymaster's Avatar
Well I've noticed some buildup on the covers themself and the wires, and it started after I installed the valve cover wires. I'll definitely take a better look at it. If I remove the valve cover, will I screw up the gasket?
Old Sep 1, 2003 | 12:00 PM
I just did my intake not but a whole month ago... what i notice when the engine is at full operating temp is little bubbles coming from the valve cover itself right about the pass side rear plug????? it my valve cover gaskets or the valve cover itself.... any one using fel pro gaskets? if so what part # ? how long do these using take to replace? like an hour?
Old Sep 1, 2003 | 12:01 PM
gb95zconv's Avatar
No it is reuseable...if it does look screwed up however you will need to replace it if you cant get it worked out.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
ModdedNerd
Jan 29, 2015 07:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
