Oil leak from water pump?
Old 04-18-2005, 02:12 PM
st08x's Avatar
is it possible for oil to leak from the bottom of the water pump? its starting to get all over the bottom front of the engine... is this a common problem? how hard to fix?
st08x is offline
Old 04-18-2005, 02:23 PM
1-bad-z28's Avatar
Re: Oil leak from water pump?
it's not coming from the waterpump. It's either a leak from the timing chain cover or the front of the intake.
1-bad-z28 is offline
Old 04-18-2005, 04:48 PM
SWINGRRR's Avatar
It could be coming from the shaft that drives the pump. Those seal are notorious for leaking if they dont get put back on just right.
You should check out www.speeddensity.org also. There are forums specific to 93's. We would be glad to have you.
SWINGRRR is offline
Old 04-18-2005, 07:57 PM
RichJ's Avatar
I've got the same issue on my 95 right now and am wondering where to start.
RichJ is offline
Old 04-18-2005, 10:35 PM
st08x's Avatar
i'm positive its not coming from the intake cause one i had the gasket replaced a couple months ago and two because it doesnt start getting messy till the bottom of the water pump
st08x is offline
Old 04-19-2005, 08:00 AM
1-bad-z28's Avatar
it's usually not the gasket that leaks on the intake, it's the rtv in the front. It could be the waterpump drive shaft seal on the timing cover. Go to autozone and get a dye kit. Be sure to check it often because if it starts leaking all over the place then you can't tell where the dye is coming from.
HectorM52
07-30-2017 11:46 AM
Magenta_Hearts
03-29-2017 08:54 PM
Magenta_Hearts
03-25-2015 10:24 AM
94Z28LS1toLT1
01-15-2015 07:18 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: Oil leak from water pump?
