OIL LEAK. Think its coming from the cam seal.
Old Apr 7, 2008 | 07:05 PM
RCMcamaro's Avatar
I was told that the cam seal on my 1997 z28 camaro is leaking oil. If i take off the opti spark distributor is there a seal there?
The car has over 100,000 miles. Would it be a good idea to replace anything else while i have it apart? water pump, opti spark, etc..
Old Apr 7, 2008 | 08:17 PM
brianswimmer23's Avatar
yea their is a seal their i have a write up on how to change it out! depending on how old your waterpump and hoses are and what shape they are in would be the determining factor on what you will want to change out!
http://www.impalasuperstore.com/nais...TOPIC_ID=30984
Old Apr 8, 2008 | 08:40 PM
RCMcamaro's Avatar
Thank you brianswimmer23.
Thanks to your pics im going for it. Does the motor have to be at TDC before i remove the opti?
Old Apr 8, 2008 | 09:03 PM
evilundisguised's Avatar
No, the opti will only fit onto the locating dowel on the cam snout one way so it doesn't matter what position the crank is at.
Old Apr 8, 2008 | 09:55 PM
...but the opti will not slide by the crank hub unless the engine is at 1 or 6 TDC where the wide part of the hub spokes are pointed up.
Old Apr 8, 2008 | 10:05 PM
Good point, I wasn't thinking along those lines.
Old Apr 12, 2008 | 12:16 PM
RCMcamaro's Avatar
Thanks for all the help. I just got the distributor out and oil had come out of it. I was just wondering if the distributor is sposed to have some oil in it somewere?
Old Apr 12, 2008 | 01:52 PM
Nope, oil should not be inside the opti
Old Apr 13, 2008 | 09:41 AM
RCMcamaro's Avatar
I bought o-rings for the water pump, but i dont see a old o-ring on it. It does'nt look like theres a spot for one to go on.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
