Oil Leak, PSU or Manifold Seal? w/ Pics
Old Sep 7, 2010 | 05:44 PM
Sick97SS's Avatar
Snapped a few pics of the back of my lt1.
Can't tell if the leak is coming from the pressure sending unit or the manifold seal cause it's such a mess...Had a "buddy" telling me the manifold seal would only create a small drip because there's no pressure behind it, while the PSU would cause a misting or a spray when they leak... What you guys thinking?
After some brake clean and engine running........where is the source?!
Old Sep 8, 2010 | 08:59 AM
RamAir95TA's Avatar
That third picture looks pretty convincing of the intake manifold leak, IMO.
What I would do is do the intake manifold gasket, and while it's off, reseal the OPSU. Might as well.
Old Sep 8, 2010 | 09:32 AM
Sick97SS's Avatar
eesh i was hoping you wouldnt say that. haha
I still cant figure how the oil would get on the PSU if the manifold seal is bad. this would mean the oil is leaking upward :/ Maybe just wishful thinking....
Also my oil pressure guage used to be nice and smooth as the RPMs climbed up. Now it seems to be notichy and twitchy when i give it some throttle it spazzes all over the place. Is this a sign of a bad sensor or a clogged galley leading to the sensor?
Old Sep 8, 2010 | 11:00 AM
Z28SORR's Avatar
Not always, you can get a "seep" from the PSU. You could clean (spray with degreaser) this area, and then check it while it's running. Might give you a better idea of what's leaking.
Old Sep 8, 2010 | 04:04 PM
Sick97SS's Avatar
The last 2 pics are after a little brake cleaner with the engine running. I can't see anything back there unless i stick the camera back and snap some pictures. Any advise to spot a leak short of mirrors and a flashlight??
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
