Oil Leak, PSU or Manifold Seal? w/ Pics
Snapped a few pics of the back of my lt1.
Can't tell if the leak is coming from the pressure sending unit or the manifold seal cause it's such a mess...Had a "buddy" telling me the manifold seal would only create a small drip because there's no pressure behind it, while the PSU would cause a misting or a spray when they leak... What you guys thinking?
After some brake clean and engine running........where is the source?!
eesh i was hoping you wouldnt say that. haha
I still cant figure how the oil would get on the PSU if the manifold seal is bad. this would mean the oil is leaking upward :/ Maybe just wishful thinking....
Also my oil pressure guage used to be nice and smooth as the RPMs climbed up. Now it seems to be notichy and twitchy when i give it some throttle it spazzes all over the place. Is this a sign of a bad sensor or a clogged galley leading to the sensor?
The last 2 pics are after a little brake cleaner with the engine running. I can't see anything back there unless i stick the camera back and snap some pictures. Any advise to spot a leak short of mirrors and a flashlight??
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
