Oil leak from the opti?
Old Feb 29, 2004 | 10:45 PM
  #16
InjectedSS's Avatar
Originally posted by Spinner
Water pump bolts onto where stock was. Old hole for shaft is plugged with a freeze plug
WERD
Old Feb 29, 2004 | 11:03 PM
  #17
Spinner's Avatar
Originally posted by InjectedSS
WERD
FZCK the stock pump. Its a PIECE.
Old Feb 29, 2004 | 11:23 PM
  #18
I have not had any kind of leak from my timing cover water pump drive seal. My original seal was still good at 82k miles when I replaced it as preventative maintenance during a cam install. I have had the timing cover off again since then and did not change the seal. Still no leaks. I like my mechanical pump, too.
Old Mar 1, 2004 | 01:06 AM
  #19
InjectedSS's Avatar
and you know this
Old Mar 1, 2004 | 01:15 AM
  #20
KyleBlue85Iroc-Z's Avatar
Re: Re: Oil leak from the opti?
Yea cause it's coming from the piece of $hit water pump seal.. Good luck getting that thing fixed... It will NEVER BE RIGHT.. Even if you do get it on right.. It will leak soon again... Those things are soo $hitty that I finally bypassed that hole all together and put an electric WP on!
I don't exactly agree with this either. I changed my opti out and have noticed a leak underneath it too. I'm fairly certain it's the timing chain cover or the above-mentioned crank seal.
I'd make sure I looked everything over before I go doing a 4-5 hour job and come to find out you didn't fix it!
Good luck.
Kyle
Old Mar 1, 2004 | 01:22 AM
  #21
revtime's Avatar
Mine was leaking from the Water pump drive seal as well, was a royal PITA to get the new seal in but I have not had any problems since.
I like the mechanical pump too..
Old Mar 1, 2004 | 01:24 AM
  #22
May-haps I could be wrong then! But I would still get both checked out before jumping into it.
Old Mar 1, 2004 | 01:45 AM
  #23
InjectedSS's Avatar
Re: Re: Re: Oil leak from the opti?
Good luck.
Kyle
nah your wrong Im right!
Old Mar 1, 2004 | 01:46 AM
  #24
Well, I'm glad you're not over-confident!
Old Mar 1, 2004 | 01:53 AM
  #25
InjectedSS's Avatar
Well Im glad that your glad Don't worry dude, not everyone can be right
Old Mar 1, 2004 | 08:26 PM
  #26
Hotwire's Avatar
not to sound like an idiot, but what is the secret to getting the seals on without messing them up? I''ve put a brand new timing cover on, then replaced both seals and they still leak.
Old Mar 1, 2004 | 09:58 PM
  #27
scoobysnax83's Avatar
yea you know that first hand don't you?
Ooo you just got side swiped by the scoobster
Old Mar 2, 2004 | 12:47 AM
  #28
InjectedSS's Avatar
The scoobster I bet you get all the hotties with that line
Old Mar 2, 2004 | 12:51 AM
  #29
only the tall blonde ones with all their teeth
Old Mar 2, 2004 | 02:00 AM
  #30
InjectedSS's Avatar
DAMN you got me there, I gotta agree on that one
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
