Oil leak from the opti?
Old Feb 29, 2004 | 07:05 PM
ollie-99's Avatar
i have a huge oil leak.
I wiped everything down and i saw oil comin from under the opti. I guess it could be from higher up as well just leakin down the opti?
any suggestions?
Old Feb 29, 2004 | 07:22 PM
CL21376's Avatar
My car was doing this too.
Dealer said it was the front seal leaking, not the opti.
They replaced both. Then again, it was a dealer...
Old Feb 29, 2004 | 07:31 PM
ollie-99's Avatar
front seal from where
Old Feb 29, 2004 | 07:34 PM
md1's Avatar
md1
What did it cost to have them done?
Old Feb 29, 2004 | 07:55 PM
CL21376's Avatar
According to the invoice:
"Tech found the front crank seal and the lower bolt for the optispark leaking oil at bolt hole."
I got the opti from jason cromer (sp) for $280.
Labor for the opti was $328
Labor for the seal was $96.58
Total parts and labor, etc. was $577
If your going to a dealer, shop around--the pontiac dealer wanted $2000 for labor on the same procedure!
Old Feb 29, 2004 | 08:09 PM
md1's Avatar
md1
Thanks I have a leak in the front but a big leak in the back. Front about the sizes of a dime and the back about the sizes of a dollar bill, not good
Old Feb 29, 2004 | 08:10 PM
ollie-99's Avatar
do u gotta take of the water pump for all that?
Old Feb 29, 2004 | 08:13 PM
InjectedSS's Avatar
Re: Oil leak from the opti?
any suggestions?
Yea cause it's coming from the piece of $hit water pump seal.. Good luck getting that thing fixed... It will NEVER BE RIGHT.. Even if you do get it on right.. It will leak soon again... Those things are soo $hitty that I finally bypassed that hole all together and put an electric WP on!
Old Feb 29, 2004 | 08:16 PM
ollie-99's Avatar
with an electric wp no more problems??
Old Feb 29, 2004 | 08:29 PM
InjectedSS's Avatar
Nope, I bypassed that seal ALL TOGETHER... Thank GOD NO MORE LEAKS EVER AGAIN
Old Feb 29, 2004 | 08:30 PM
ollie-99's Avatar
hmm not a bad idea
If i was to keep the stock WP how long will it take me to complete this job?
Old Feb 29, 2004 | 09:27 PM
InjectedSS's Avatar
hmm not a bad idea
pull the fans off, drain the coolant, remove the wp bolts, then pop the old seal, then spend who knows how long even trying to get the new seal on.. Which you will more than likely BREAK so then you have about 2 more on hand to try to do right I would say a couple hours.. Just cause that seal is such a PITA... I seriously got tired of it.. I got mine on and thought it was perfect and that pucker leaked AGAIN So I said screw that $hit and finally by-passed it
Old Feb 29, 2004 | 09:53 PM
All4Chevy's Avatar
When you get an electric water pump.....what happens to where the stock pump is. How is that area closed off?
Bill
Old Feb 29, 2004 | 10:10 PM
Spinner's Avatar
Bill
Water pump bolts onto where stock was. Old hole for shaft is plugged with a freeze plug
Old Feb 29, 2004 | 10:43 PM
chrp3rd's Avatar
its from the timing chain cover trust me do that and the intake trust me willl save you a big headache
