Milled heads/new combustion chamber size??
Old Mar 1, 2004 | 05:26 PM
Fastbird93's Avatar
My heads were milled .010", and I NEED to know what this did to my combustion chamber volume. Need to know for new shortblock. Thanks.
Old Mar 1, 2004 | 08:15 PM
Steve in Seattle's Avatar
measure it.
Old Mar 1, 2004 | 08:33 PM
Fastbird93's Avatar
Heads aren't off the car. Trying to figure out combustion chamber size for new motor setup.
Old Mar 1, 2004 | 09:13 PM
Ai's Avatar
Ai
You can typically figure .006" per CC when flat milling...
Of course valvejobs, chamber work etc. will all make a difference as well...
Old Mar 1, 2004 | 10:09 PM
trax's Avatar
I remember reading that you can use a buret to pour water into one of the chambers and get a volumetric measurement. The machine shop you had the heads milled at should have some method similar to this of approximating your chamber size.
Old Mar 2, 2004 | 03:04 AM
Fastbird93's Avatar
Well, can anyone make some educated geusstimates using the following info: 2.02/1.55 valves, milled 0.010".
I talked to the ported yesterday, and he said that the slight milling will only have a very negligible effect on the CR, if any.
Nayr
Mar 3, 2023 08:34 PM
colts0455
Sep 11, 2015 06:16 PM
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Jul 24, 2015 02:25 PM
