Oil leak from low oil sensor
Old Jan 9, 2004 | 02:53 PM
THEMADTYPH00N's Avatar
I've found an oil leak that is comming from the bottom of the big nut that is on the drivers side of the oil pan. Its got an electrical connector going into it so I asume it is a low oil level sensor. Anyway it seems to just be seeping out from the very bottom of that nut. Above the but is completely dry. Is that nut just threaded in there and can I tighten it up? Is there a gasket? Thanks.
Old Jan 9, 2004 | 03:36 PM
gb95zconv's Avatar
Its threaded.....just drain out the oil and take it out....clean up the threads and put some rtv on them and put it back in and you should be good.
Old Jan 9, 2004 | 07:31 PM
Stoopalini's Avatar
How many miles are on your car?
When the oil level sensor gets old, it can start leaking through the center of the bolt (where the wires connect). Worse than that, the small float inside will break off and be stuck in the oil pan!
Here's a few threads on my experience with that little sensor:
http://web.camaross.com/forums/showt...hreadid=209768
http://web.camaross.com/forums/showt...hreadid=203582
Thomas.
Old Jan 9, 2004 | 07:43 PM
scyzoryk's Avatar
I have new oil sensor for sale. I paid $30 shipped, I wil sell for $20 shipped...
Sebastian
Magenta_Hearts
Mar 29, 2017 08:54 PM
artic94
Jan 17, 2015 11:19 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
96z
Sep 5, 2002 07:53 PM
