Maf?
Old Jan 9, 2004 | 07:16 PM
TArider21's Avatar
Question Maf?
Is the MAF supposed to make a loud sucking noise while the car is running? Mine does this, and I've had problems with the MAF before, and am just wondering if my MAF is going bad.
Old Jan 9, 2004 | 07:57 PM
hot_red_z28's Avatar
Your MAF shouldn't make any noise, the engine might be sucking in enough air to make that noise though. If you have the air box or CAI taken off then sure, you will hear a sucking noise. One way to tell if your MAF is going bad, if you are really concerned about it, is to start up the car, and while it's idling, just tap a screw driver on top of it. If the idle jumps around when you tap it, something is loose or messed up, if nothing happens, you are good to go...
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
