Oil leak and knock help please
Old Sep 27, 2004 | 07:56 PM
brad20653's Avatar
Two seperate things Im sure but I noticed a oil leak kinda constant from the from coming from the bottom valve covers are dry so not that. Also it had a horrible exhaust leak at the donut is there a gasket in there?? Well i tighten the bolts were almost off it was so loose and sounded quieter but when i start it has kinda of aknock or clunk just for a split second like on something older when you set the timing wrong its kinda like that. Any ideas??? 96 z28 6 speed
Old Sep 27, 2004 | 09:38 PM
indieaz's Avatar
Re: Oil leak and knock help please
"but I noticed a oil leak kinda constant from the from coming from the bottom valve covers"
coming from where exactly?
Old Sep 27, 2004 | 09:51 PM
brad20653's Avatar
I just see it coming from the bottom I ment i checked the valve covers and there dry all around. Whats the most common in the front? What about that knock?>
Old Sep 27, 2004 | 10:43 PM
indieaz's Avatar
you're gunna need to jack up the car and get under there i think. It could be coming from the front of the oil pan or maybe around the timing cover (around the opti seal possibly).
So are you saying the exhaust is making a knocking noise or the engine is knocking? What kind of exhaust setup do you have, are there headers on there?
Old Sep 28, 2004 | 07:17 AM
brad20653's Avatar
All stock but it sounds like the engine just a split second like i said kinda like when you retard the timing on stuff that kinda wierd sound you get when you crank it but sound slike a knock.
Old Sep 28, 2004 | 09:08 AM
WS Sick's Avatar
Brad is it a quick knock like when you touch the gas or first start it?
Old Sep 28, 2004 | 10:51 AM
brad20653's Avatar
Just a quick starting knock none once its started.
Old Sep 28, 2004 | 11:07 AM
WS Sick's Avatar
So right when you start it it kncocks once or a few times then doesnt knock anymore after that. What about if while idling you tap the gas real quick?
The knock almost sounds like a loose torque converter bolt.
Old Sep 28, 2004 | 11:14 AM
brad20653's Avatar
No no noises after at all just exhaust leaks. Its a 6 speed too.
Old Sep 28, 2004 | 06:51 PM
brad20653's Avatar
Could it be the knock sensor
Old Sep 29, 2004 | 07:36 AM
brad20653's Avatar
Whats the most common leak in the front?
Old Sep 29, 2004 | 09:18 AM
WS Sick's Avatar
The front oil leak could be the crankshaft positin sensor (located low on the pass side of the timing cover) the front main seal (seal that the crank comes through the front timing cover, balancer pressed on there), any of the seals sealing the optispark or the waterpumps drive shaft. It is also common for the front rail of the intake manifold to leak as well. You just have to wipe and watch...lol. Sometimes it takes the motor to be warm and in rpms for the leak to occur (pressure inside crankcase).
As for the knock , if you have exhaust leaks the first kncock could be an exhaust leak as well.But if it goes away after start-up and never appears again it could be piston slap or a lifter that has drained down while it set. Really nothing to be alarmed about. Just be sure your oil pressure is solid never going below 20-25 at idle warm.
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
