oil leak from intake
Old Nov 16, 2004 | 10:55 AM
babyhardyback's Avatar
Unhappy oil leak from intake
Can someone tell me about the intake on the lt1? I have a oil leak coming from the front and back of the intake. My question is, does the engine have to come out in order for this leak to be fixed or can it be fixed with the motor in? My Z is a 95 auto with 150000 miles on it. Please, someone help me!!!
Old Nov 17, 2004 | 12:14 PM
Re: oil leak from intake
anybody
Old Nov 17, 2004 | 01:03 PM
Z95m6's Avatar
You can remove the intake with the motor in the car. It only takes it about an Hour or less to pop it off.
Old Nov 17, 2004 | 01:22 PM
Spinner's Avatar
What he said. Remove all the electrical stuff, remove the four bolts on the fuel rail and pop it off of the intake, then 6 bolts on either side hold the intake down. Pretty simple job.
Old Nov 17, 2004 | 01:36 PM
BoobSter-lt1-z's Avatar
Is this the "FAMOUS OIL LEAK" the LT1 is known for????
Old Nov 17, 2004 | 02:14 PM
Red_94Formula's Avatar
Yes it is. Remember to get some high grit sand paper and sand all sides (a little) which rtv is used. That will fix it for good.
Old Nov 17, 2004 | 03:14 PM
y5e06's Avatar
I would not use any sandpaper. you take a high risk of getting abrasive material into your engine via the lifter valley. stuff towels into the intake & exhaust ports, and lay down more towels in the lifter valley. Just scrape the surfaces real good w/ a razor scraper. Be careful not to gouge the aluminum head surfaces. Then clean any residue off w/ Acetone or brake cleaner. Barium (sp?) B12 works good too.
also use a good intake sealant on the front & rear. I've had long term issues w/ RTV, they eventually leaked again. I now use Permatex 'The Right Stuff' gasket maker. comes in a black cheeze wiz type can. It is awesome stuff. I'd also recommend getting GM gaskets instead of felpro etc. If you compare the two you'd see they are significantly different. Also, I've had 1st hand experiences of the felpro gaskets overlapping into the intake ports (bad for performance!), poor alignment.
The 1st time out the job will probably take you 4+ hours. half of that seems to be the cleaning process.
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
