Oil Leak and High Idle
Old Dec 17, 2004 | 11:56 PM
curt'95Z's Avatar
I have an oil leak that migrates to the back side of the engine and across the tranny pan. I read on a 4th Gen website that this is a symptom of intake gasket gone bad; any experience out there on this?
I also Idle way too high. Is this the throttle position sensor going bad?
If I am going to be tearing into the Intake Manifold and TPS, what mods would be the best bang for the buck while I am in the top end of the engine?
Old Dec 18, 2004 | 12:16 AM
tabroker's Avatar
Re: Oil Leak and High Idle
Check your EGR valve. Oil can leak from the gasket going bad, and can cause a vacum leak that would explain your high idle.
Old Dec 18, 2004 | 08:46 AM
curt'95Z's Avatar
Thanks. I'll Check it out.
rideordie
Nov 5, 2019 04:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
