Oil Leak Blues
Oil Leak Blues
hey guys. i'm new to this site and new to the LT-1. I have a 95 Formula with the M-6. i have a pretty severe oil leak from the rear of the motor. i assume it is the rear seal or oil pan gasket or both. i have been told i will have to pull the motor out to fix this. can this be done in the car or is it better out of the car? i plan to replace the crank seal and timing chain gasket(as well a timing chain set) and put a new water pump and tune up. also adding headers. any help would be appreciated.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
