Oil leak on back of engine on 1994 LT1
Old Feb 3, 2010 | 06:30 PM
jeremykelly10's Avatar
Just had intake gasket replaced and main seal is showing no signs of a leak. Valve cover gaskets also look fine. Any ideas?
Old Feb 3, 2010 | 06:52 PM
camaronutt's Avatar
Oil pressure sensor is back there. Maybe its that.
Old Feb 3, 2010 | 07:01 PM
brianswimmer23's Avatar
X2 could be the problem, but get a light and a mirror and look around back their to see .
Kevin Blown 95 TA's Avatar
Depends how it was repaired. Not everyone does the intake correctly which is why it leaks in the first place - cause GM did it wrong from the factory. It's a notorious leak. If it's not that, it's possible that some is oozing out the seam between the heads and intake where they meet in the back.
Old Feb 4, 2010 | 03:46 PM
mzgp5x's Avatar
I had rear and front engine leaks. 2 leaks @ rear intake manifold. So, I installed a 1/32" groove in the intake and roughed up the rear china wall. Used Permatex Grey and let it set-up for 1 to 2 hours. Installed manifold carefully and slight finger tight torque. After 4 hours did a final torque. No leaks there now.
I have also had rear main seal leaks. The app is a 97ss 383 FI. It got better when I used a Lucas oil stabilizer (very little oil leak). I have since went to an external crank driven VAC pump. No leaks @ all now, and, about 20 more hp. I think rear seals tend to leak when the engine is off, but, I'm guessing. I know, it is dusturbing.
I've also had front oil pan seal leaks also.
Rear main seal housings can be a problem w/ not being installed concentric w/ the crankshaft. I have found the GM rear seal parts to be better than the Felpro due to dual ribs.
Hope this helps you. B.
Old Feb 5, 2010 | 10:42 AM
JAKEJR's Avatar
For years I've done something similiar to 5x, I dimple both China Walls and the corresponding areas on the intake with a nail set.
I have a photo showing them on the 388 I was building for my 96 Vette. Let me know if you'd like to see it.
I also have a STICKY posted on LS1LT1 on how I do my engines if you'd like to read my method. There are others that may works as well, but the one I posted works for me.
Hope this helps.
Jake
Old Feb 5, 2010 | 10:56 AM
wrd1972's Avatar
Hope this helps.
Jake
If I ever pull the intake again, I am going to do this.
Old Feb 5, 2010 | 10:56 PM
corkss's Avatar
That sounds good!!! I just may use that idea..NIiice
Red Hawk 94
Mar 18, 2019 04:03 PM
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Scottylt1
Dec 4, 2014 12:31 PM
Jul 4, 2005 05:00 PM
