Oil Leak after Opti install
Old Nov 18, 2003 | 09:37 AM
Fast96WS6's Avatar
Just like the subject says. After installing the opti, the car leaks a good amount of oil while stoped after driving. It didint leak at all after the install. I'm guessing I tore the seal that the opti sits in on the timing cover. The opti driveshaft o-rings were brand new so I dont think its that. Also, the front main seal is brand new.
TIA
Old Nov 18, 2003 | 12:28 PM
Fast96WS6's Avatar
anyone? TTT
Old Nov 18, 2003 | 12:51 PM
madwolf's Avatar
I would clean the timing cover area real well and see where the leak originates from. It may be the waterpump seal, may be the opti seal, crank seal... or even the oil pan gasket...
Old Nov 18, 2003 | 08:32 PM
Bud M's Avatar
What seals did you replace? The water pump drive seal is easy to tear on the "step" on the water pump drive shaft. You have to put something with a cone shape on the shaft so the seal won't tear. stretching out the inside of the seal helps too.
Old Nov 19, 2003 | 08:54 AM
Fast96WS6's Avatar
The oil is definetly coming from behind the opti. I'm thinking its prob the Opti seal, but I'll check the WP Driveshaft seal as well
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
Queens94z28
Dec 20, 2014 09:11 PM
GigaMp3z
Feb 20, 2003 02:57 PM
96z
Sep 5, 2002 07:53 PM
