Oil Leak!!!
Old Apr 10, 2008 | 01:37 PM
97_Z28's Avatar
Oil Leak!!!
I have a 97 Z28 LT1. It has been running great, then all of a sudden I'm leaking oil out of the front of the motor. Not a lot about a 4'' by 5'' puddle over night. I'm thinking it may be the water pump shaft seal. Anyone else have any suggestions? Thanks.
- Lee -
Old Apr 10, 2008 | 03:30 PM
Dave1980's Avatar
clean everything up, and then look for the oil leak. Might use some brake cleaner. You have to catch them from the exit point, or everything is just a blur it seems. Also how high up the oil is on the motor can give clues, since oil cannot run upwards.
Old Apr 10, 2008 | 07:23 PM
97_Z28's Avatar
True, that's what led me to believe that it's the water pump seal. Thats the highest point as far as I can tell. I still need to check the head cover gaskets. Thanks Dave.
Old Apr 10, 2008 | 08:48 PM
klrz28's Avatar
All LT1's love to leak. I just rebuilt mine and its already starting...
Old Apr 11, 2008 | 12:22 AM
Dave1980's Avatar
I think we have several more areas that can leak compared to the norm.
Old Apr 14, 2008 | 12:22 AM
Lt1t56's Avatar
You can clean it off, check for a leak and replace that seal.
If you find that a seal in the timing cover is leaking, I would buy a Fel-pro timing cover gasket set and replace all seals. Water pump drive, opti, and crank seals.
Also on your 1997 there is a crank sensor in the timing cover. There is a o'ring on that sensor that can leak oil also, but that usually wont cause a leak that leaves a small puddle overnight, but something else also to consider.
Old Apr 14, 2008 | 02:16 PM
RUDEDOG's Avatar
Do a search on installing the installing the water pump seal. You need to make a tool so you don't roll the lip. Many people get burned on this and it starts leaking again.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
