Oil Leak ..
Old Aug 27, 2007 | 12:57 AM
96supersport's Avatar
Oil Leak ..
runs down the front of the block... and on the sides.... possibl intake manifold gaskets????
Old Aug 27, 2007 | 03:40 PM
seawolf06's Avatar
It could be the front of the intake manifold, the timing cover or the opti/waterpump seals. Spray it down really well with brake cleaner and then run it to see where it's coming from. There is no gasket on the front of the intake, should just be RTV. The opti/wp use ring-type gaskets and the timing cover is just a paper gasket.
Old Aug 27, 2007 | 04:32 PM
IXLR894Z28's Avatar
LT1 intake manifolds are notorious for leaking, easy fix though.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
