oil leak
Old Aug 25, 2007 | 09:50 AM
camarocrzy's Avatar
Angry oil leak
i have a mysterious oil leak that is driving me insane. i thought it was the intake leaking,so i replaced the gasket. It still is leaking so it isnt that. My question is:what would be leaking when my car is just sitting without running? its not leaking alot,three drops over night. But i am just trying to figure out what could be leaking with out running the car. it cant be the valve covers causeit leaks without running. Any ideas?
Old Aug 25, 2007 | 09:56 AM
dangalla's Avatar
first of all the only place the intake will leak there is no gasket for you must use rtv to make your own gasket
under the car can you see the oil leaking down and trace it up, i know on my car the oil level sensor was leaking
Old Aug 25, 2007 | 10:01 AM
TrybalRage's Avatar
I feel your pain, man.
I have a leak that leaves spots, and worse, drips on the exhaust somewhere so I smell oil burning at stop lights and such.
I'm afraid it might be the rear main.
Old Aug 25, 2007 | 10:07 AM
Harvey's Avatar
Is the spot that collects over night at the front, back, or middle of the motor? That might help in getting some suggestions as far as where to start looking.
Old Aug 25, 2007 | 11:29 AM
camarocrzy's Avatar
its dripping off the front of the bell housing.
Old Aug 25, 2007 | 03:57 PM
dangalla's Avatar
reach your hand around the back of the motor and feel where the intake meets the block in the middle, if its wet pull the intake and re-seal that area with rtv
Old Aug 25, 2007 | 05:11 PM
Wims97T/A's Avatar
And when you are there also check the sealing of the oil pressure sensor,i had a small leak there also.
Old Aug 26, 2007 | 02:48 AM
adamc's Avatar
ive got the same problem rite now kinda agravating since i just changed the oil so im not gonna fix it till next time... i took the oil level sensor out this past time i changed oil and did a liltle silicone job on it siliconed both sides of washer and in the sensor plug and popped the plug in place no luck
it dont leak as bad now but i can tell where its leaking from ne ways where the plug goes in somewhere around the 2 metal wires that goes into the plug inside the sensor
how much these babys run usually $$$?
Old Aug 26, 2007 | 08:11 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I got a GM oil level sensor for ~ 13 bucks.
Dude, I'm originally from Bowling Green. I graduated from Western and used to date a girl from Greenville. Small world.
Old Aug 26, 2007 | 09:13 AM
adamc's Avatar
Names Adam Croxton you may know my uncle Darin Croxton hes on all these f body boards quite a bit user name is... fast(something)
who'd u date in greenville may know her?
I was just up at bowling green here while back got my car dyno tuned there and some other computer tuneing. i cant think of the name of the shop tho.
nice to meet ya
Old Aug 26, 2007 | 09:34 AM
BTC's Avatar
BTC
I sent you a PM.
Old Aug 26, 2007 | 12:26 PM
camarocrzy's Avatar
what is it that accutually leaks oil from the oil pressure sensor,the part that goes into the block or the back of the plastic piece? im having a hell of a time trying to figure out where its coming from. i used a crap load of rtv when i did my intake oil leak. I am thinking its the sensor thats leaking and making me think its the intake leaking again.
Old Aug 26, 2007 | 12:30 PM
Dave89IROC's Avatar
they rarely leak where they screw in, usually leak through the sensor and out the plug, if you unplug the connector and it's wet, the sensor is leaking
is there any oil on the back of the engine?
intake/oil PSI sensor are not the only spots that will cause it to drip from the bellhousing
Old Aug 26, 2007 | 01:28 PM
camarocrzy's Avatar
its leaking from the back of the intake and dripping down on the back of the oil pan and onto the bellhousing. my only other suspect parts are the valve covers and oil pressure sensor. i used alot of copper rtv when redoing the intake,so i think i got it right the first time im hoping. its wet and greasy on the back of the intake around where the sensor is.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
