oil leak
i have a mysterious oil leak that is driving me insane. i thought it was the intake leaking,so i replaced the gasket. It still is leaking so it isnt that. My question is:what would be leaking when my car is just sitting without running? its not leaking alot,three drops over night. But i am just trying to figure out what could be leaking with out running the car. it cant be the valve covers causeit leaks without running. Any ideas?
first of all the only place the intake will leak there is no gasket for you must use rtv to make your own gasket
under the car can you see the oil leaking down and trace it up, i know on my car the oil level sensor was leaking
it dont leak as bad now but i can tell where its leaking from ne ways where the plug goes in somewhere around the 2 metal wires that goes into the plug inside the sensor
how much these babys run usually $$$?
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I got a GM oil level sensor for ~ 13 bucks.
Dude, I'm originally from Bowling Green. I graduated from Western and used to date a girl from Greenville. Small world.
Names Adam Croxton you may know my uncle Darin Croxton hes on all these f body boards quite a bit user name is... fast(something)
who'd u date in greenville may know her?
I was just up at bowling green here while back got my car dyno tuned there and some other computer tuneing. i cant think of the name of the shop tho.
nice to meet ya
nice to meet ya
what is it that accutually leaks oil from the oil pressure sensor,the part that goes into the block or the back of the plastic piece? im having a hell of a time trying to figure out where its coming from. i used a crap load of rtv when i did my intake oil leak. I am thinking its the sensor thats leaking and making me think its the intake leaking again.
is there any oil on the back of the engine?
intake/oil PSI sensor are not the only spots that will cause it to drip from the bellhousing
its leaking from the back of the intake and dripping down on the back of the oil pan and onto the bellhousing. my only other suspect parts are the valve covers and oil pressure sensor. i used alot of copper rtv when redoing the intake,so i think i got it right the first time im hoping. its wet and greasy on the back of the intake around where the sensor is.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
