oil leak
Old May 28, 2007 | 02:44 PM
1994greenz28's Avatar
oil leak
I just changed the oil(instead of the usual fram oil filter i went with the k & n) after about 80 miles, i noticed a leak...it leaked out about 2 quarts...there was oil on the the bottom of the oil pan, flywheel cover, and trans pan...i can not figure out wear the leak is coming from...
Old May 28, 2007 | 02:52 PM
2000GTP's Avatar
Start easy, are you positive the old oil filter gasket was removed before putting the new filter on? Is the filter tight and the drain plug tight?
Old May 28, 2007 | 03:28 PM
seawolf06's Avatar
Spray it all down with brake cleaner and then run it until it leaks(not driving it). You should be able to see where it's coming from then.
Old May 28, 2007 | 04:39 PM
i figured it out...the oil cooler lines were loose...problem solved
Old May 28, 2007 | 08:31 PM
seawolf06's Avatar
Take it off, permanently. You'll thank me later.
Old May 29, 2007 | 08:36 AM
2000GTP's Avatar
Yeah, it seems they cause more problems then good, they have been known to get clogged and lead to some oil pressure issues.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
