O2 fouling out, 110 octane
Old May 27, 2007 | 05:20 PM
kline454's Avatar
What o2s can i use that wont foul with 110 i had the AC ones then they fouled now running bosch and im fouling them like every three weeks.
Old May 27, 2007 | 05:41 PM
rskrause's Avatar
Moderator
There are none that I am aware of that are comaptible with leaded fuel.
Rich
Old May 27, 2007 | 05:57 PM
Dave89IROC's Avatar
denso sensors are lead resistant, they should last at least a season before fouling
http://www.densoaftermarket.com/products/?id=1
Old May 27, 2007 | 06:29 PM
The Engineer's Avatar
Sunoco makes an unleaded 104 octane race gas, which is their GT-Plus product name. Technically it isn’t a street legal, due to the fact it is oxygenated. That is what I run in my 396 stroker w/ 12.2-1 compression.
WD
Old May 28, 2007 | 02:57 AM
Z-RATED94's Avatar
Kline, why do you need 110 octane?
Old May 28, 2007 | 04:50 AM
badzboy11's Avatar
I use VP Motorsport 103 and it is o2 sensor safe.
Old May 28, 2007 | 10:42 AM
I believe the VP 103 unleaded is about the same as the Sunoco GT-Plus (104 octane).
WD
Old May 28, 2007 | 09:45 PM
kline454's Avatar
11.3c.r +150n20, and i just fouled another o2 is there anyway of cleaning them? im going to start running 100 octane.
Old May 28, 2007 | 11:10 PM
Z-RATED94's Avatar
New o2 sensors and and some unleaded 100 octane should do the trick. If your set-up for nitrous was done right with all the bells and whistles, including colder plugs, I have no idea why you would run 110 leaded octane. 11.3 compression is really not that much. 93 octane pump gas should be just fine.
Old May 29, 2007 | 08:55 AM
kline454's Avatar
its a tune from madz28 for the nitrous, and i run colder plugs tr6.
Old May 29, 2007 | 10:19 AM
buzz12586's Avatar
You should be fine on 93 octane gas if the tune is setup for nitrous. Now if you were running a more aggressive tune I could see you needing race gas.
Old May 29, 2007 | 10:34 AM
EnerjetF67's Avatar
I run the Denso O2's on my 383 and have no problems with running AV100 LL or Torco 110, both of which are leaded (AV has 2.0gr/lead/gal, Torco 110 has 4.0gr/gal)
Incidentally in my area of the country I can now buy AV100 LL (which is between 110 and 115 R+M/2 pump octane) for less than pump 87 regular, and Torco 110 for $4.00/gal, which is only $0.25/gal more than pump premium.
Go figure.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Nov 5, 2015 04:33 PM
RX Speed Works
Sep 11, 2015 03:31 PM
Henson071
Aug 4, 2015 09:32 AM
RX Speed Works
Jul 24, 2015 02:25 PM
