Oil Filter Leak
Old Aug 15, 2007 | 05:51 AM
CL21376's Avatar
Oil Filter Leak
I've tracked an oil leak to the oil filter (using engine dye). This will be the second time this has happened--the other was diagnosed by the dealer a couple years ago. But based on the dime sized drips under my car, it's never stopped.
I'm using either Mobile 1, AC or K&N Oil Filters. There is no residual gasket material on the oil filter plate. I'm applying a little oil to the gasket on the filter prior to installation.
I had the oil cooler off when I installed my headers last summer and I'm sure it's on tight.
Any idea why I keep leaking oil from here? Is there a gasket between the filter and the block? Or anything else in that vicinity that could be leaking?
Thanks!
CL
Old Aug 15, 2007 | 08:20 AM
GetaZforgetGT's Avatar
There is no gasket between the cooler and the block.
I would drop the oil cooler and clean everything up and put it back together with a clean dry surface and see if that helps.
Old Aug 15, 2007 | 08:44 AM
There may not be a gasket between the adapter and the block, but I believe there is a gasket between the cooler and the block (like an oil filter gasket).
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
