Oil Filter Leak
Oil Filter Leak
I've tracked an oil leak to the oil filter (using engine dye). This will be the second time this has happened--the other was diagnosed by the dealer a couple years ago. But based on the dime sized drips under my car, it's never stopped.
I'm using either Mobile 1, AC or K&N Oil Filters. There is no residual gasket material on the oil filter plate. I'm applying a little oil to the gasket on the filter prior to installation.
I had the oil cooler off when I installed my headers last summer and I'm sure it's on tight.
Any idea why I keep leaking oil from here? Is there a gasket between the filter and the block? Or anything else in that vicinity that could be leaking?
Thanks!
CL
Thanks!
CL
Jul 4, 2005 05:00 PM
