oil everywhere
Old Dec 25, 2008 | 03:29 PM
jtarp's Avatar
oil everywhere
Ok...i know my car has been leaking oil for a while now, as there is always some on the ground. I just got up under the car the other day and noticed that the entire underside of the car is covered in oil. Usually when i see it on the ground it is more than just a few drops. Motor is still running fine though. Do you guys think it is the Rear main seal. That is what i am starting to think. I don't believe it is the oil pan gasket or the rear of the intake. Any other ideas or am i going to have to replace the RMS?
Old Dec 25, 2008 | 04:01 PM
Stl94LT1's Avatar
I would double check the rear of the intake.
Old Dec 25, 2008 | 04:35 PM
jtarp's Avatar
Ok thanks. I will do that shortly.
Old Dec 25, 2008 | 05:04 PM
henryz28's Avatar
Could be the oil sending unit behind the of the intake.
Old Dec 25, 2008 | 05:13 PM
jtarp's Avatar
Ok. I'll check that also. Thanks
Old Dec 25, 2008 | 10:32 PM
Blownbird355's Avatar
If the drops are in different spots it could be leaking from a few places.
Old Dec 26, 2008 | 12:13 AM
jtarp's Avatar
Its kind of hard to tell if it drops in a few spots due to the fact that there is usually a small puddle on the ground maybe about the size of a softball or so when it sits.
Old Dec 26, 2008 | 01:28 AM
TBSPW's Avatar
jack the car up and get under there...prolly the intake or main seal
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
