Oil coming out my EGR?
Old Feb 1, 2007 | 09:42 PM
madhatter's Avatar
So I went to take off my intake yesterday, and when i was holding it vertically by the TB holes, oil dripped out of my EGR. What the hell is causing this?
Old Feb 1, 2007 | 09:46 PM
OBE1 95Z28's Avatar
It's common for oil to be sucked into the intake via the TB tube that runs to the passenger side valve cover. It can also come from a faulty PCV. Over time oil accumulates in the intake. When you tipped it up on end, it ran down to the EGR.
Old Feb 1, 2007 | 11:06 PM
madhatter's Avatar
Yes but my car hasn't been ran in 3 weeks. There shouldn't have been any oil up in there...
Old Feb 1, 2007 | 11:59 PM
Oil doesn't evaporate.... it can puddle and sit there forever. But I'm not so sure about the theory that it leaked out the EGR hole because the manifold was hanging vertically. There is no direct connection from the back of the manifold to the EGR port. The EGR port is routed under the bottom of the manifold, and I think it combines with the idle air at the front of the manifold. That would mean that the idle air passages were full of oil. That would be possible if there was excessive flow of air out of the passenger side valve cover to the top of the TB, with the oil actually dripping down directly onto the idle air port between the throttle blades. But then you would have had idle problems if the idle air passages were filled with oil.
Pull the top plate off the throttle body and see if its full of oil.
Old Feb 2, 2007 | 02:59 PM
Mauiguyy911's Avatar
when i pulled my TB plate off there was a lot of oil in there, is that bad?
Old Feb 2, 2007 | 03:07 PM
I could be normal... there always seems to be some "backflow" in the line from the passenger side valve cover to the throttle body. Ideally, the PCV is pulling a vacuum on the crankcase, and air is flowing from the TB to the valve cover through that line. But at times of low vacuum and high blowby (WOT) its possible for the flow to reverse, entrain oil droplets and put them into the top of the throttle body. If the accumulation is excessive, it may point to a non-working PCV system, or excessive blowby on the piston rings. Or it could be the baffle in the valve cover is missing.
Old Feb 2, 2007 | 06:04 PM
OBE1 95Z28's Avatar
Good time to add a wet nitrous system; the atomized fuel in the intake track will clean that oil right up
HectorM52
Jul 30, 2017 11:46 AM
edman
Mar 13, 2015 09:39 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
