Oil changing to dark brown 2 early
Old Oct 28, 2003 | 09:35 PM
96Z28TealM6's Avatar
I did an oil change about 1550 miles ago and it's already like dark brown...and I'm using Mobil 1 5W-30...should I change it to 10W-30? What do you think is happening?
Old Oct 28, 2003 | 09:41 PM
Seal's Avatar
after like 500-600 it'll get dark enough that its opaque
Old Oct 28, 2003 | 09:45 PM
magius231's Avatar
the dark color you see in oil (normally) isn't due to dirt or contaminates, its what happens to the oil due to heat cycling, and its perfectly normal.
so do you think this is a sign of burning oil or what
Old Oct 28, 2003 | 09:47 PM
okay thanks magius231
Old Oct 29, 2003 | 04:32 AM
Patman's Avatar
Oil color means nothing, even when oil darkens quickly it can still do a good job. Diesel engines instantly turn their oil black, but most diesel trucks go tens of thousands of miles on the same oil. (of course they have HUGE oil sumps too, which helps a lot)
Old Oct 29, 2003 | 04:40 AM
S.J.S.'s Avatar
I dont wanna hyjack this thread so I'll make a new one.
Old Oct 29, 2003 | 06:30 AM
TedH's Avatar
It is possible you could have an intake leak. I assume you are asking because it didn't used to turn color so quickly and now it does.
grabbem88
Mar 18, 2015 01:25 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
