Oil around spark plug?
Old Dec 5, 2003 | 03:19 PM
kgkern01's Avatar
Question Oil around spark plug?
While I was under my car putting in clear corners, I noticed some oil around the front driver side plug. There is NO oil above this point, but was some on the outside of the plug and on the head and block underneath where the plug goes in the head. I took the plug out, no oil on the plug, not sure where this oil could possibly come from. Any ideas?
Old Dec 5, 2003 | 03:27 PM
jasons93z's Avatar
it sounds like it could be the front intake manifold gasket going bad.
Old Dec 5, 2003 | 03:34 PM
kgkern01's Avatar
Where does the intake usually leak from, the front or the back?
Old Dec 5, 2003 | 03:40 PM
jasons93z's Avatar
it is usually known to leak from the back, but it can leak in the front also. I have a front intake leak, but its not to bad.
Old Dec 5, 2003 | 03:59 PM
kgkern01's Avatar
What is weird is that there is NO oil above this point around the plug, just below it.
Old Dec 5, 2003 | 04:18 PM
96z's Avatar
96z
Maybe bad rings and loose plugs? Or too much antiseize that got dirty?
Old Dec 6, 2003 | 02:54 AM
kgkern01's Avatar
There is no oil on the part of the plug that is in the cylinder, only on the outside of the plug, none on the plug wire either. Runs fine, not sure where it came from, I guess I will try to clean it off and see if it comes back.
Old Dec 6, 2003 | 06:18 AM
Hyperspeed97z28's Avatar
I have oil all over the last plug on the pass side... I believe my valve covers are leaking... 88k on the clock now.... More then likely, Just did the Intake leak bout 15k ago...
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
