Oil around spark plug?
While I was under my car putting in clear corners, I noticed some oil around the front driver side plug. There is NO oil above this point, but was some on the outside of the plug and on the head and block underneath where the plug goes in the head. I took the plug out, no oil on the plug, not sure where this oil could possibly come from. Any ideas?
There is no oil on the part of the plug that is in the cylinder, only on the outside of the plug, none on the plug wire either. Runs fine, not sure where it came from, I guess I will try to clean it off and see if it comes back.
jasonduaine
Mar 7, 2015 09:44 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
